Newly laid porcelain floor tiles over UFH, showing lines,
Hi
saw the mats down and no overlapping..once UFH turned on was only set at a ro9m temp of 20 degrees, floor temp never much above 14 deg,
he was meticulous with each tile is all I can say , as not had this work done before.
not sure if vitrified as just described as porcelain, was not aware of the term vitrified until recently .
They are described as glazed porcelain..
I would run the UFH for a few weeks and see if it improves. Fingers crossed it might.
thanks, have agreed with tilers that as tiles were laid couple of weeks before heating was hooked up, that would leave till end of March and in meantime they are seeking sone advice from the adhesive suppliers who will probably say the same.
thanks For you input , appreciated.
Hi
Vitrified means that the tile isn't porous to any problematic level of moisture. Porcelain is a material designed for very low porosity, hence it's outdoor use in cold climates and hard wearing properties.
Best Floor Tiles
Ian gall,
Ian gall,
Ian gall,
Ian gall,
