I
Italy
yes marc, I'm interested in BATTILESome interesting items Antonio. 🙂
It will be approximately £130 in U.K.
I am concerned however may be too lightweight. Sometimes I find extra weight helps.
Maybe this will work similar to regular orbital sander?
Battile is cordless tho. (that's what interests me)
1mm thick blade. A bit thinner than my go to CGX blade I’m using which is 1.3mm
Blade of 1 mm, requires use of tutorcut1mm thick blade. A bit thinner than my go to CGX blade I’m using which is 1.3mm
Some lovely tooling as usual from Montolit. I look forward to having a proper look when I get home. Some good ‘sat on the toilet’ reading.
Thanks @antonio
The reason the CGX is 1.3mm is because in the uk minimum blade thickness allowed is 1.2mm.
The 1mm blade won’t be sold here as it’s too thin.
