Discuss Nightmare !!! The Tiler Will Get Over It in the Australia Tiling Forum area at TilersForums.com.
There a wall on other end?
Hi sean
That's a possibility. There is a low window raveel almost straight after the bath ends.. I'm tiling full height one side and half height the other with no trims ( I know!! Not my idea ) so any board will show
I think it's the short end of the bath in the pic Dan, the hole is too big.No bath is too fixed before it is tiled. Scribe it in, it should move an inch. If not use flexi pipes to the taps and stick ball valves on them while you're at it. Get that bath move back. It'll only need to go back so much because of the tile and adhesive thickness etc
Down he wall to the bath and where a tile goes beyond it, let it go beyond it. Finish it all off and then let the customer who bought the wrong bath or the plumber who fitted the wrong bath get the wrong trim or wrong quadrant to cover said massive gap lolTile down where? You mean tuck behind the bath and go down the wall?
Reply to Nightmare !!! The Tiler Will Get Over It in the Australia Tiling Forum area at TilersForums.com
