Oh no.... my tiles are discontinued....
It would be great if all tiles HAD to have a code on the back and be submitted somewhere, so you know who the manufacturer was at least.
Something along those lines has been tallked about we just need someone with the know how to set it up.....Anyone know of someone like that ? DAN! :smilewinkgrin:
Thanks for the replies.
I think that they have cracked because the tiles are not level (on a slight slope) in the kitchen. Plus there is no adhesive under the tiles.
I don't know why they are cracked I think I need someone professional to come and fit the tiles for me, and also to provide advice so it will not happen again (LOL) epseically if I can only source 2-3 of the tiles.
I have 3 tiles cracked are all lined together. The downstairs is complete with tiles apart from my lounge, so re-tiling will cost a small fortune. Hence why I thought yippee when I found a tile match and then the distributor has stopped selling them :yikes:
sounds like you need to re do it from scratch,buying more of these tiles doesnt sound liek your problem is gonna go away mate,good luck:thumbsup:
you answered your own question as to why the tiles cracked
theres no addy under them
no point patchin them bunny as other tiles will crack in time
I know I know, we're nearly there lol. Got the domain name and hosting setup. Like all good things that come to those who wait, it's just a bit of time now it needs. 😀
Sounds like they have been spot-fixed (blobs of adhesive in the corners etc instead of actual being fully covered). If you tap the tiles with a coin you should be able to tell where adhesive is and isn't under them as you get a dull sound where adhesive is suggesting a solid bit and a higher pitched sound, almost a ping, where the tile had a void under them.
Any tile that's spot-fixed will be prone to cracking as the weight of everything above it isn't being evenly distributed. In essence the tile is taking the weight and not the sub-floor.
I'd seriously get that checked by a professional before just doing a repair as I think you may find it'll just keep happening.
And that without taking into account any other problems. You said the floor slopes, that's okay providing the tiles have been fixed properly but if they're now just starting to slope that again suggests a sub-floor issue and the tiles will crack whether they have been fixed properly (with a solid bed) or not.
If you have a sub-floor problem AND spot-fixed tiles the lot will need to come up for sure.
