Discuss OK ANY SUGGESTIONS from in the British & UK Tiling Forum area at TilersForums.com.
Diamond Pool Finishers
you top tiler's as to how to fix large format por's, to a stainless-steel floor that will move,in a swimming pool.
so the things to think about are as follows.
fixing to a stainless-steel sub straight.
that will flex,
that is underwater & out of water.
in hot /warm/cold water.
with a chemical mix in the water.
i will ask various adhesive manufactures ,to supply me with a spec. but any offers of how you would approach this would be an interesting read........ oh and i will post the results from said manufactures :thumbsup:
Mike Mike
Questions of clarification first.
Why will it flex?
How much flex will there be?
How thick is the stainless steel, and what grade of stainless steel?
Please clarify why it will be "underwater & out of water".
"In hot / warm / cold water". Clarify the temperature changes please.
The Danish shipping line DFDS have tiled floors in their wetroom floors on their ferries. I do not know if the substrate is stainless steel, or galvanised steel, or what spec, but it is steel. So right from the off, in principle, this is doable.
I will lay down a marker and say epoxy resin adhesive and grout. Subject to your responses to my questions, then I'll fine tune it with a suitable manufacturer and spec if I can. Can't say fairer than that :thumbsup:
Mike Mike
I think Swedish Mike should have his Trusted Advisor badge by now.:8:Don`t you?
That's very kind of you Luke, but in fairness, I'm just guessing at the moment. I know that steel can be tiled onto, but the clincher is stainless steel, which is a much more difficult proposition I think (try welding stainless steel for example...).
Mike Mike
i only know at the mo that it is stainless steel,
https://www.youtube.com/watch?v=PChL21DBu94 this is the kind of thing,
i will get to know more as it all come's to light
and will do a complete job run through if i get the job , oh it's in Hertfordshire
At first I had no idea what I was watching, but eventually figured it out. But what really made my day was looking at the comment someone had posted:
"Seems legit", ROFL. :lol:
you can have a stainless steel mesh tacked ( welded ) on to it maybe for a mechanical key ?
doug boardley
Why will it flex?
great post!!! one of the best I've read:thumbsup:
doug boardley
I shall ask the wife,,,,she's a welding lecturer and is coded to ASMY 9 (?), she served her time welding stainless water turbines.
Reply to OK ANY SUGGESTIONS from in the British & UK Tiling Forum area at TilersForums.com
11K
Rizzle from the Portizzle
http://www.*************************.com/water-underfloor-heating-152-w.asp Supplying Water...
10K
6K
Hi I have 6 bathrooms to do with 900x330mm ceramic tiles 160m2 of 900x600mm limestone I''ve...
12K
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
