Outdoor Tiling | Tiling outdoors
Hi All,
I am looking to install normal outdoor porcelain tile (8mm) over existing brick pavers. I could remove brick pavers as well but I am not sure how do I need to prepare the ground for tiling. For tiling over existing brick pavers, I am thinking to wash and prime brick paver and do sand and cement bedding (about 20-30mm thick) to lay tile over it.
Another option that I have seen on your tubes is to remove brick pavers and then put about 50mm compacted road base and then sand & cement bedding on that to lay tiles.
With both options, I am also not sure if the normal outdoor porcelain tiles which are about 8mm thick would be strong enough? Normally outdoor paves are 20mm thick. The reason for going for normal outdoor tile is cost. 20mm pavers are too expensive compared to 8mm outdoor tile.
Please suggest what would be better way to do it. I also considered just laying concrete with dimond cut pattern to make it look like tiles but thats bit expensive as well ($60 per sqm).
Thanks a lot.
Hi guys this need help I layed some gritty outdoor dark tiles but they get water stain and hold the dirt and don’t look good. I tried Dunlop enhancing sealer but it’s rubbish. Does anyone know of a heavy duty permeating wet look sealer?
We have an original, Victorian quarry tile path leading to our front door.
Several of the tiles are cracked or loose and need replacing.
The tiles are laid on compacted earth which is very solid (photo attached).
Is it worthwhile lifting the broken tiles out, replacing with reclaimed equivalents and then grouting in with flexible grout? Or is this a short-term fix, and the whole path should be lifted and relaid on a new cement base?
DIY'er - so appreciate any advice
I've had some great advice on here before and i'm back for some more - mainly about adhesive choice.
I built a gazebo in the back garden earlier this year and have put a hot tub under it. The concrete has been down for 3 months and it'll be 2-3 months max before i start this job, so still quite "fresh". I plan on using standard dotti r9 tiles (prob 300x300) straight on to the concrete, but as the concrete is so new i'm not sure if i should use a decoupling mat (if so, which one?) and i have no clue what adhesive i need and how thick i should trowel it.
The tub is 2.1m x 2.1m and would easily tip 2.5 T when full of water and people. Ideally i need something that will cure up quickly enough that i can get the hot tub moved back on to it in 2-3 days max - even if i had to wait maybe another few days before refilling it. It also needs to be suitable for outdoor use and easy enough to work with for a DIYer. I could tile around the tub without moving it, but it would probably look a bit half-assed and would have the potential to retain water underneath the tub, which i don't want. The total area is roughly 9m2.
Any advice, tips, pointers gratefully received.
Just finished a job laying 20mm porcelain 600 x 300 slabs. Laid on a sand and cement 1/4 mix for a patio with a hot tub. Straight onto concrete sub floor. Slabs and concrete cement and bonding agent slurry applied to both surfaces. Hot tub placed and filled with no issues.
PS, Make sure the cement is semi dry. i.e not too wet. you should be able to form a handful of cement in your hand and it should retain its shape and not break up or be wet ( If that makes sense) 10 -15mm bed will be sufficient.
Hi all, I am currently having my patio tiled under my pergola with a Matt porcelain patterned tile. It's called the azteca blue tile and the manufacturer has said it does not need to be sealed.
It has a rough anti-slip surface which looks like it could trap dirt. My question is does this need to be sealed or would I be wasting my time and money sealing it?
If I do seal it, I was thinking of using the ltp porcelain tile pre grout protector before it's all grouted next weekend. What are your thoughts?
Please contribute to this thread if you have any new information or can even just reiterate what has been said already. 🙂
No they don’t need sealing.
Kyle Knowles,
parkerfresh,
Kyle Knowles,
parkerfresh,
