outside corner in rectangle bathroom
mr angry
hi guys,
please excuse my terminology if i dont describe my current diy job. i have just ordered tools from amazon... cube laser, trowel, float, grout etc... i have not ordered the leveling tile kit yet as there are so many to choose from so hopefully someone can recommend a cheap good kit.
anyways, i am about to start tiling my bathroom but im not sure how to tackle the outside corner inside the bathroom. my choice is the offset method rather than the stacking one. maybe you can convince me otherwise :/
i would also add that i cannot get the rest of the pant off the wall as its stuck pretty good. ive read on google that all paint should be removed or by doing heavy scores in the plaster to make the adhesive bond. what do you recommend for heavy scoring the walls as i feel using a razor blade is not suffice.
i also have to tile the floor and upon checking this it looks like a 9m ply was used for the tiles already laid. should i use the same thickness of ply when i do the floor? if so, then i will be left with a step up into bathroom like before (not a big problem) around an inch height. i need to rip it all up anyways due to radiator pipe work and water inlet for toilet being offset.
the measurements for wall width 22cm for left width and 45cm for the right width. the tiles for the wall are 298mm x 498mm bought from b&q. if you need any more info please tell me.
should i start tiling the walls first or the floor?
thanks
cameron
after checking a few tiles at the window area i had a few loose tiles which i took off to investigate. the window wall seems to have been made up of plasterboard and then a skim of brown plaster on top with a plastic wire mesh stuff inside it, downwards from window area, which is different from the side walls where this is made up of about an inch of white plaster, not sure if there is any mesh inside it but in comparison seems a lot thicker and better stability that the brown plaster on the window wall.
from where the tiles were loose there seems to be no mesh in this area towards the ceiling and side areas of window. when i pulled a few tiles off, the thin layer of brown plaster came away with the adhesive and was very weak however the rest of the wall seems intact and ok. im assuming that when this was done the need for this wire mesh was missed out left and right side of the window.
also, im not going to use the mapei super grip on last wall. so what stuff should i buy going forward from b&q or screwfix or anything else to help finish this job 🙂
thanks for your time guys 🙂
is there a particular brand of primer for the last wall i need to finish from b&q, screwfix or somewhere else?
i have seen a few different ones....everbuild sbr bond, bal bond sbr, bal primer, bal prime apd..... which one is specific to my cause? i did read the prime apd which states for dusty tiling substrates, should i buy this one?
please help!
cheers
You should really use the same manufacturers primer as your chosen adhesive and I don't buy from B&Q so don't know what they stock, have you not got a tile giant or Topps or even a local independent tile shop you can buy from instead? Where ever you get it from you'll need a mix with water bagged slowset adhesive..
can anyone tell me if i can use bal white star plus ready mix adhesive and is it better than the mapei super grip? someone local is selling 7 tubs of it for £50 so was wondering if this would kill 2 birds if i dont need to prime the walls or would i still need to prime the walls if i purchased the bal stuff or not bother and buy the powder slow set stuff.
i also have an option with weber set rapid spf 20kg bags x 5 for £50 if thats better i can get that.
cheers
That will be fine but is going to go off pretty quick.
A standard setting adhesive may be better if your not that quick tiling.
We use Tilemaster standard setaflex on walls, gives a few hours working time, but it’s used up before it goes off anyway.
Bathroom Tiling Advice
Unsolved
mr angry,
mr angry,
