grumpygrouter
Softening adhesive with a steamer is relevant to dispersion adhesive and it is only to soften the adhesive to aid scraping it off. The same caution needs to be applied so the paper coating of the board isn't damaged. I personally abrade any painted plasterboard back to the paper surface and no further. I can agree that scoring will give a "key" but if you penetrate the paper surface you are weakening the board as that is what gives it it's strength. Wheather it has been done that way or not for years doesn't make it "right"imo.......pva has been used as a primer for years too....
Oh, and i wasn't "challenging" your advice nor was I suggesting your were incompetent and I don't know why you mentioned that. I was giving an opinion to your response as that is what the forums are about...help, advice and debate. If you think what I said is wrong then that is fine, but at least the readers have now been given a different opinion to consider if the situation arises for someone else.
