Guest viewing is limited
Discuss perla 230 how to change blade in the UK Tiling Forum area at TilersForums.com.
E
enduro
ello all and a happy christmas to you all...........got a perla 230 ...havin major trouble changin the blade.....got spanner for it but cant work out how to stop middle spindle turnin.......any help would be appreciated.....cheers paul
I have a perla 230 the way you have to do it is put the spanner on the nut hold the blade whith your hand (with gloves on health an safety) then with a rubber mallet hid the spanner quite hard and the nut will become free. Andrew
N
nick.v.g
to change the blade you need to use a 6mm hex key into the shaft on the motor side, there is a central access hole in the plastic cover or you can just take it off after removing the 2 phillips head screws.let the hex hey run fast against the steel cover plate, then you can loosen the nut on the spindle, its a contra nut, so its clockwise to loosen as you face it. just clamping the blade wont work as the blade will just turn on the spindle if its been on a while. took me two days to figure that out I was just about ready to take a large sledgehammer to it:incazzato:. checking the date from the last post I've got a feeling problem has probably been solved but who knows. Nick
Reply to perla 230 how to change blade in the UK Tiling Forum area at TilersForums.com
Hi , I've recently been in a job using 750x750 5mm porcelain tiles, they cut fine on the score...
5K
One Day
How to drill a hole in a steel bath. At 365Drills we provide either the equipment you need or...
6K
Deleted member 1779
Hi All , could really do with some help on the above bridge saw. This was a second hand purchase...
7K
mache
So I've had my 1200 for a while now and it's done 5-600 cuts, mainly travertine, 610 x 405 x...
25K
Jelthetiler
Had to smile at this but if anyone offended by language etc I will remove but cant see it having...
Gazzer
south london
