Discuss Plasterboard or Plywood in the British & UK Tiling Forum area at TilersForums.com.
Molster
Hi
Never used a forum before - so hope I get this right!
I have a question regarding preparation, not tiling. I'm making ground floor bathroom into a wetroom. The walls are brick with no cavity. Size 2m.20 x 2m.50 x 2m.60 floor to ceiling. It was originally battened out with 25mm timber, with 25mm insulation and plywood sheets fixed to the battens. My intention is to fix 50mm battens to the original battens and put another 50mm insulation in. The room will be fully tiled, and kitted out for a disabled person. That's the background - now the question. What would be the best material to line the room, and tile onto - 12.5mm moisture resistant plasterboard - or 20mm plywood?
DHTiling
Right fine.......I would go with gaza's advice but maybe Dot&Dab the boards on with cement based adhesive direct to the brick work....this will give flatter walls if the brick work is slightly out as battening will just follow any lumps & bumps unless you spend time packing out etc...Dot&Dab will be much quicker.....:thumbsup:
Reply to Plasterboard or Plywood in the British & UK Tiling Forum area at TilersForums.com
Hi all, Quick question, when installing 6mm backer board onto a floor prior to tiling, would...
Hi everyone, I'm having the majority of the ground floor of my house tiled (35m²) and I'm not...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Please see rough sketch. My ensuite is 2x2 m with the door opening into the left into the room...
Hi everybody, I've taken on the task of tiling my own kitchen, and before I wreck everything and...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
