Discuss Plastic ply in the UK Tiling Forum area at TilersForums.com.
I assume you don't use it to strengthen floors in your installations?Hi basically the PVA / primer is to seal any dusty areas that are apparent after brushing down the surface .I have used plastic ply from the beginning ,trialing it for my local branch ,and as some one has said it does what it says on the tin .I have used it it on floating floors in excess of 30 sq mtrs ,floor boards ,weyroc floors and even ware wood floors have joined into screed.As long as the instructions are followed you won't find a better or easier product to use on the market and it's only 2mm thick.:hurray::hurray:
Me too!!I have seen this stuff in local tile shops, I would not risk using it Looks OK for Diy, I don't fancy laying a floor on cellotape as one guy from Dural called it. I don't see how it can be classed as a decoupling membrane. I have read all the tech stuff on Ditra and CI That makes sense, crack isolation, lateral movement etc. they do nothing to overcome deflection. IMO this is a gimick, if I need to overcome deflection I will use a suitable backer-board. If I need to overcome lateral movement or green screeds liable to shrink with curing, I will use Ditra or CI. No blue tack for me thank you
Reply to Plastic ply in the UK Tiling Forum area at TilersForums.com
