Please help a Newbie
Well done Les! Job done well under TJ's guideance :thumbsup:.
Have you run a line of Silicon up the corners too? (I can't tell from your pics). If not, then it will be worth doing, white or clear will look good.
Thanks Captain Slow.
The corners between the back and side wall are done with BAL Microflex.
Should I run Silicon over the Microflex?
Grout won't stop water ingress, so I would Silicon over the grout in the corners. Not ideal, but seeing as the grout is flexible you should be fine.
Well said Captain Slow...........
TJ
I have just booted up and spotted the above because this evening I have done exactly what Captain Slow recommended and Siliconed up the corners so I am pleased to see that you are in agreement with this refinement TJ.
Tonight, however, I used a bit of improvisation of my own. I found a plastic card that was slightly bigger than a standard credit card and snipped off the rounded corners so that they were straight across but of different sizes and used this card to do the first smooth and removal of excess Silicon. Just a short length at a time before wiping the card clean on some paper towel. This gave me an excellent start for TJ "wipe the grit from a baby's eye" technique with Fairy Liquid on the end of my index finger. I found that the edges of the card removed any excess Silicon a treat from the tiles on either side of the corner by angling it a bit as need be. :thumbsup:
The corners do look better than before but not worth a picture because I think it would be difficult to make the difference show in a photograph.
I even got the carpet cut back to accommodate the bigger base and relaid on it's gripper so the job it pretty much done and dusted all bar the acid test of using it for a while and checking for leaks, God forbid! :yikes:
For the sake of completeness here is a list of the main materials, new tools and the suppliers that I used for this refurbishment of my shower:
900 x 900 x 95 mm Shower Tray...................Primrose Bathrooms Sheffield (c/o eBay)
900 mm Bi-fold Door.............................Primrose Bathrooms Sheffield (c/o eBay)
P-Trap..........................................Primrose Bathrooms Sheffield (c/o eBay
18 mm Weather Proof & Boil (WPB) Plywood........Wickes Stafford
Esmeralda Beige 200 x 300 x ~9 mm Tiles.........Wickes Stafford (Surplus from earlier work)
White 200 x 250 x ~5mm Tiles....................Wickes Stafford
Carbide Edged Grout Routing Tool................Wickes Stafford
Plaster Board and Timber........................Wickes Stafford (Surplus from other work)
Mapei Keraquick (Grey)..........................Trades Direct Newcastle Staffs
Mapei Latex Plus................................Trades Direct Newcastle Staffs
Mapei Primer G..................................Trades Direct Newcastle Staffs
Mapei While Silicon Sealer.....................Trades Direct Newcastle Staffs
Mapei Keraquick (White).........................Tile Giant Cannock
BAL Microflex (Microban) Flexible Grout.........Topps Tiles Stafford
BAL While Silicon Sealer.......................Topps Tiles Stafford
Notched Spreader "Vinyl" for Adhesive...........B&Q Stafford
Flexible Spreader "Vinyl" for Grout.............B&Q Stafford
Saw Edged Blade Grout Routing Tool..............B&Q Stafford
Grouting Sponges................................B&Q Stafford
Disposable Vinyl Gloves.........................B&Q Stafford
Dulux Bathroom+ White Paint for the Ceiling.....Wilkinson (Wilko) Stafford
The two weeks for the BAL Microflex to cure, set, harden or whatever it needs two weeks to do before the shower could be used was up yesterday so use the shower I did and so far it is all good news. :thumbsup:
I ran the shower for 5 to 10 minutes with the floorboards in front of it lifted and inspected all the couplings in the drainage plumbing and they stayed nice and dry and there were no sign of any leaks that I could detect. 🙂
So with that I took a shower, my first since the 2nd of May. 😉
After that I inspected the plumbing again and looked where I could for any signs of leaks and fortunately couldn't find any.
I know that leaks can be time related but so far it's looking good, albeit early days.
My
once again to all who contributed and to TJ in particular.
No shower since the 2nd of May?? i'm surprised you were brave enough to look at the pipes afterwards they must have been black lol.
It's a pleasure Les, Keep inspecting it once in a while just to make sure no teething problems occur but if it's fine now it should be fine for a long time.
Good luck to you mate, i'm pleased you enjoyed it and are happy with the end result
TJ
Hi Les
It's been a while since the showerroom got started but we are now at the stage of fitting the door. I notice all the shower doors are in from the edge of the tray and I think ours is going to look daft as you are only going to see about 1" of tiling outside the shower cubicle as we have only tiles the 3 wall areas around the shower tray.
Is it imperative that the door be centred on the rim of the tray.?
Hi Les
There may be others better qualified than I am to reply but provided that the door frame can be sealed to the wall tiles and the rim of the tray, whether it is exactly centred or not shouldn't matter. I have just had a look at mine and the bottom is forward of centre of the tray rim because the verticals are not symmetrical inside and out. I guess the answer has to depend on the particular door you have to some extent.
Have a look at the picture I posted and see if it helps you make up your mind.
most shower screens are set back between 10mm & 25mm from the outside edge........ But as long as your happy that wherever you set it it is watertight you will be fine.
Most shower trays have a slight raise on the outside edge so if your setting your your screen more towards the inside edge just make sure it opens and closes smoothly
TJ
Oh yeah and when it comes to runing your Silicon around the shower screen just do the inside edges only (Obviously leaving the door opening so you can get in and out lol) INSIDE ONLY!
tj
Just bumping some of the older popular (sometimes not so popular) threads. Probably wont be current discussion these days but I just need to do it. So just ignore the thread if it's not current for you.
LesD,
Dan,
LesD,
Dan,
