Guest viewing is limited
Discuss Porcelain Equivalent Of Black Quartz Stardust in the Australia Tiling Forum area at TilersForums.com.
berilac
Hi all,
A newbie here and looking to buy the black quartz starlight or stardust,
Stardust Black 60x60 | Topps Tiles
Is this porcelain ? If not I was wondering if there was a porcelain equivalent of that I could purchase online or in a shop,
My tiler has recommended porcelain and prefers that over Granite,
ST
gamma38
1,058
Bedford
I wouldn't buy an online equivalent for cheaper. There have been a few threads on here regarding problems people have had with them. The stardust from Topps you would be fine with or as Whitebeam says a galaxy granite.
mmmm, not sure i totally agree with that statement, yes there are some online stores selling real bad cheap quartz, but there are some selling gulfstone, which is the same tile as stardust.
berilac
Thanks, Thats good to know, which ones would you guys recommend?
Also on granite galaxy do you know how much heavier it would be compared to stardust? They seem to be at a good price as well approx £20m2,
berilac
As long as it's genuine Gulf Stone, that's the phrase you're looking for.
You would have to check with supplier on weight of the Galaxy, it will depend on the thickness.
fyi - the tiler I am corresponding with has mentioned that Granite is generally thicker, i.e. it will add more height to the floor.
gamma38
1,058
Bedford
Not really, it's not the difference between 10 and 20 mm it might be a couple of mm between them. I don't mean to be the doom and gloom of online suppliers but i had some granite from an online and it was a long way out of tolerance, i.e. should have been 300 x 300 but some pieces were 295 and some 305 etc. Before you buy from someone without being able to view the stock just ask them to give you the tolerances in writing.
Reply to Porcelain Equivalent Of Black Quartz Stardust in the Australia Tiling Forum area at TilersForums.com
hats67 - Yesterday at 11:48 PM Add bookmark #1 Hello guys. I came upon and registered with...
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
Hello! We have an issue with 12 cracked large format thin porcelain tiles (1500x1500x6mm). They...
Hi there, I want to tile my small kitchen floor, it is around 7-8 square metres and has an...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
