Porcelain Equivalent Of Black Quartz Stardust
thanks guys , this forum is great and your advise is much appreciated, I got the hardie board from tops tiles as well and that was a great tip,
Though it seems I still have problems, today my tiler mentioned he would have to add the hardboard on top of the vinyl tiles I already have , there is a problem where the vinyl is stuck on the floor below and is breaking that up, in this case the height of the kitchen and bathroom will go up by 12-14mm. What would you suggest.
I have two options,
- add another layer of Vinyl on top of it
- or add the hardboard and stardust tiles over them
Regards
ST
Nah, get the vinyl up. Maybe he doesn't fancy doing it cos its a bit more work, could you offer to do it?
If its a 1st floor in an Edwardian house they'll be stuck onto ply on-top of the original floor-boards perhaps?
Best approach is to get right back to the floor boards and start again, gluing and screwing the Hardibacker boards down to the floor boards.
its stuck and it won't come off without causing wear and tear to the ply and he reckons we would have to lift the whole kitchen out to replace it, am thinking its maybe simpler if I just add Vinyl to it for now and later get the whole thing done,
i was advised to go with bal ptb and ad1 mix for the stardust... Certainly should be a two part, as I understand it two much moisture can bow the quartz tile
Sounds like a bit of a faff to me, I thought it was a simple bathroom refit, didn't know there was a Kitchen involved too?
Dunno what to suggest, depends how much you want the job done, and whether the kitchen is staying forever??
lol , I am getting the kitchen and bathroom retiled with the same stardust tiles, I have the same problem in them though so its consistent,
I would have gone ahead with it but not sure if tiling over the vinyl is a good idea,
I personally think you should cut around the kitchen units, remove vinyl and whatever ply comes up with it, same in the bathroom, and when you fit the Hardieboard you can self-level the floor to bring it up flat before tiling.
If it isn't going to be done this way, I wouldn't do it, I guess the Hardiebacker could go down over the vinyl, but in effect its ONLY the screws holding it down that way, adhesive underneath not doing much. If he insists on going this way, as long as he compensated with extra screws with adhesive it might hold....but it'd be a heck of a step-up from other rooms.....
The adhesive used with Hardi isn't used to hold it down.
It's purely used to take out unevenness of the substrate.
The screws are used to secure it to the floor.
Oh right, I wasn't aware of that, trust me when I've cut through some onto floorboards for a plumber to access something its stuck fast!
So it could be ok then (apart from the height)
Well if u were over boarding with ply for example, would u still remove the vinyl flooring?
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
