Discuss porceline adhesive in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
I prefer to use a cement based adhesive with porcelain but ardex do a tubbed adhesive which would be fine for small format tiles.....
ARDEX D 30
Size (pack): 10ltr
Coverage: Approximately 1 litre per m² using a 3mm x 3mm toothed and notched trowel.
ARDEX D 30 is a water resistant, non-slip ready mixed wall tile adhesive for use in commercial and domestic showers, kitchens and bathrooms. Suitable for virtually all substrates and tile types, including porcelain, ARDEX D 30 does not need a primer and is easy to use with excellent application properties.
ARDEX D 30 is classified as D2 TE (improved dispersion adhesive with additional characteristics, reduced slip and extended open time) in accordance with BS EN 12004.
or use a cement based one.......
BAL Single Part Flexible
A flexible, non-slip, water-resistant and frost-resistant wall and floor tile adhesive, especially suitable for fixing tiles, including fully vitirfied and porcelain tiles to low porosity backgrounds/bases. Suitable for use on concrete/brick/block walling, cement:sand rendering, plaster, plasterboard, cement sheets, tile backer boards, concrete bases, cement:sand screeds, plywood overlay, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet bases, mastic asphalt. Conforms to BS EN 12004, Type C, Class 2T.
And don't forget to use a flexible grout........
good luck.....:thumbsup:
bal tas 2
Hi stu5705
sorry about the long post but this should explain why a cement based adhesive should be used for porcelain tiles.
Ready mixed ceramic wall tile adhesives require moisture to be lost from the adhesive in order to allow the polymer binder to dry and forma ‘FILM’ capable of bonding both to the substrate and the tile.
A High proportion of large format tiles, typically 30cm x 30cm or greater are typically porcelain and as such, by definition the tiles have a water absorption of 0.5% or less. Therefore this would slow down the hard formation between a ready mixed ceramic wall tile adhesives and a porcelain tile. If the background is also of a low porosity or is in fact impervious to moisture, the ability of the adhesive to “dry out” would be severely hampered, bearing in mind that the only rational escape route available to this moisture would be via the open grout joints. The larger the tile, the fewer the joints, thus reducing the amount of open areas where moisture may escape. For this reason, Building Adhesives Ltd would recommend the use of cementitious based adhesives as a general rule to ensure the adhesive is capable of drying and setting beneath the tiles.
hope this helps bal tas 2
grumpygrouter
Yes my tiler warns about grouting too quickly.. Once the grout goes in the moisture can be trapped behind.
But I am not a tiler! - So I leave the adhesive advice to the experts..
But dont forget your diamond drills !
Don't let anyone ever accuse you of not being a trier Richard! :lol:
Grumpy
Reply to porceline adhesive in the British & UK Tiling Forum area at TilersForums.com
Morning everyone Hope you're having a good weekend. Does any one have any recommendations...
    • Friendly
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
porceline adhesive
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
