Discuss Priming Insulation Boards in the Canada Tile Advice area at TilersForums.com.
yeah I thought the samesorry read it wrong thought you ment no more ply
Hardie is a cement board.I always prime Hardi & no more ply but just run over cement boards with a very damp sponge before fixing onto them....
It depends on the make of primer, they all have different densities. It'll tell you in the data sheet. Treat it like your priming a skimmed wall, first coat well diluted 2 or 3-1 to allow it to soak in and second coat 2-1 or neat, it depends on the primeris that xps boards as well, and if so (as I'm about to lay some) what ratio primer to water please
Reply to Priming Insulation Boards in the Canada Tile Advice area at TilersForums.com
