Profile gauges.
  • Thread starter Thread starter wivers
  • Start date Start date
  • Tags Tags
    usa
Hi , THe best way is to take the pan and sink out - makes a far better job. I come from a Karndean/Amtico background, where the shop had to go round fittings - I used to carry a roll of 2.5mm Twin and Earth Electrical Cable round with me. Its easy to bend round curves and holds the shapes with speed & very little mess.
but is it perfect arttay?
It pretty good - takes a bit of practice to get used - It all depends on time you have to devote to the cut - I was always taught the correct way is to scribe, like previously mentioned. But when you your sent on job that should be a day and half and they give you a day to complete it, as you know - you adapt your own methods - I'm sure you know how it is......
I thought I'd mention - If the complete wire was too bulky - I'd just strip out one of the cores and use that.
always open to new suggestions, im still learning after all this time, need to try the wire method but still needs you to have wire on hand, not into buying wire just to scribe a pan with, honest practise with scribing can be done in no time, its how your doin it.
Can anybody do pics or diagram on how to scribe around toilet pan
the best way is to try and not to do the cut in one go, just take small bits off with nibblers until you get the desired shape...........practice makes perfect...
use paper templates the size of the tile,thats what i and a lot of the guys on here do,check some of the old threads and you will find what you are looking for.Try and quarter the pan with the tiles as this will help when cutting and nibbling out the waste tile.This advice should help.🙂
Profile gauges.
Tags Tags
usa
wivers,
Dan,
wivers,
Dan,
