Proxxon kg80 trim saw!
I've used them for many years - my advice (once built) is to keep a grinder in one if you don't want to take play with nuts and bolts (I keep my cheap Aldi one in it as a place for it to live as much as anything). Easy to set up. Super handy for many types of framing systems too.
Hi Wishi.
I think to try and explain these stands a little better this video will probably help.
As you may see if you are an IKEA expert its really your thing and also maybe why you may keep a grinder in one permanently.
The last 20% of this video may help to answer about the mitre cuts. (and a slightly different variant of stand)
They are very repeatable just not quite a straightforward as dialing in an angle on a slide saw.
It will transport well - the weak point is the hinge section - usually a diecast material. If you dropped something heavy on it I can see that breaking.
That proxxon kg80, canny price like, I wonder if there is a model making forum that might have one listed in their classified adds, as its looks the type of thing it would be used for, I have seen on here some using it, think it would a cool thing and more robust than the angle grinder for transporting, but hard to spend £200 on it.
What about this.
Blunt Tool,
GoneGuy,
Blunt Tool,
GoneGuy,
