H
Hulloo
Hey people hope u can advise me.....I am currently installing a new shower room in my house. Im upto the stage of tiling the floor. The floor is made up of wooden floorboards on wooden joists.
The floor was slightly unlevel so i decided to use everbuild self leveling compound after priming with SBR bonding and securing down any loose floorboards. This has given a great result.
The next stage is to lay down the 12mm cement based hardie backer boards.
To give the boards that extra security before screwing down using the galvanised screws, I have decided to lay the boards down on a very thin bed of dri wall adhesive (Had a spare bag lying around) then screw down when set.
My question is if i follow the above procedure would i first need to prime the self levelled floor with PVA for the dri wall to give the hardie backer a secure fix? If so what ratio mix of PVA to water and for how long should I leave it before laying the boards......
Many thanx, hope u can help.....
