Mark B
Even if you use the slot cutting method you could still drill the hole first as it would give a much neater finish around the pipe.
As mentioned, the problem with draining down the system is that you're never quite sure what's going to happen (or not!) when you fill it back up again - air locks, sludge blockages etc.
Mark
Mark
