GazTech
Cutting in around pipework can be ok if cut neatly...
Adhesive might be a better bet RichardYes in the BFKMX the 40mm will allow a rad pipe and fitting to slip through with room to spare.
The downside is that the 40mm hole looks a bit swamped.
The easy solution is a standard cover plate at 45mm.
Shown is a 15mm rad pipe being capped off with a 45mm plate. Hole underneath can be 40mm to fit through a standard rad pipe at 15mm fitted to a rad valve.
But I'd be tempted to use GazTech's standard method if you do not have an ultra fussy customer. There are projects where the extra effort is required (mainly ultra-modern contemporary) when minimilist fittings are required. Perhaps not in this case.
I just did this little article:
Tile drills for radiator pipes with our kit - By Richard Hazell of 365-Drills
1) Drill a 40mm hole into the tile.
2) Slip radiator pipe WITH the valve over the hole
3) Seat tile down onto grout and press in place
4) The Hole at 40mm looks too big for the pipe.
Slip a pipe cover over to cap off for a perfect result
i won't be getting him to service my boiler then:no:Spoke to a heating engineer today and he said he will charge £100 for draining the system and filling again just so a round hole can be put in the tile:huh2:
