Re grouting job
Ceramic/porcelain tiles? Then clean the grout and the tiles with an acid based cleaner and a toothbrush. Then use a grout colorant with a toothbrush.
You will deffo scribe your tiles if you try de grouting a 2mm grout line.
Also, how big/small are your tiles?
Yes I know it's gonna be a right mare!.....but she is having none of cleaning it up and using grout recover as she wants an epoxy ......just gotta find a perfect tool that can do it in good time that any of you guys have actually tried and tested............tiles are 200x250 ceramic.......it was only done 2 yrs ago and it's really bad, mould everywhere....., they have extractor fan and keep the window open, the tiling isn't the best so I reckon cheap grout mastic has been used here....DOH!
If she wants an epoxy then she can have one without the mess.
A grout colorant will turn your grout into an epoxy grout - honestly.
A mould spray (chlorine) will get rid of the mould in a few minutes.
I even get a few spots of mould in our shower. Well ventilated and has a fan, but the bathroom is always freezing. Single brick and crittall windows don't help. Just a couple of sprays of HG MOULD remover does the trick.
I'm not pulling your leg about the colorant. Have a look at Aquamix grout colorant.
200x250........you had better buy a few spares!!!!!
If the tilings that bad It would make more sense to start again.....polishing a turd springs to mind...🙂
Okay cheers for the advice mate, I,m gonna try & talk her round and have a go at cleaning with hg mould remover and order some aqua mix grout colourant and do a sample area and see what she thinks then........hopefully i can pull it off!
I think FEIN do a grout removal tool, but I'm not sure it goes as thin as 2mm....
Good luck on the "negotiation".
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
