Recommendations for wet cutter
I have been using be similar saw to the Erbauer -looks like it could be made by the same people. I changed the blade to an Armey PTC 180mm disc. The scale/ ruler for the fence is printed on coated paper and is wearing off, i had to adjust the motor position to have it cutting square. Aside that it's easy to clean and drain the water, I've done quite a bit of cutting with it and no problems. The original blade want much cop the replacement I got from eBay.
Jennie Jones,
Adrian mcc,
Jennie Jones,
Adrian mcc,
