Replacing Existing Floating Floor
What's the benefit from using two boards over 1 40mm board? Is this to remove the lateral movement or part of the waterproofing?
And are you suggesting wedi board to remove the need to prime the boards?
by using 2 layers you strengthen the floor as your effectively laminating it and by using wedi better water protection and also no priming so job can be done faster.
So your saying wedi board is not strong enough in one 40mm bit?
And that put sticking two 20mm boards down with the extra adhesive, fixing and mixing time is quicker and cheaper than priming with a roller and fixing one layer of 40mm board?
Well you learn something new on here every day 😉
The wedi is pretty strong. one single 40mm would be fine on rigid block and beam. Unless you weigh approximately 2 tonnes, then you may get a tiny bit of compression! Based on wedi's technical sheet.
Thats if i've got my rough calculations right.
Compression resistance of 0.25N per mm2 with the average adult foot has an area coverage of 31000 mm2 multiplied by 2 feet (in most cases) = 62000 mm2...... times 0.25N per mm2 = 24800N dead weight multiplied by 0.1019kg's per Newton = 2528 kg with both feet firmly planted although results may vary for walking, jumping or standing on one leg.
Ok, so I was half a tonne out! and thats if you're standing on the bare board. once its tiled, it'll spread the weight even more. Meaning you could burger yourself up to 10 tonnes. maybe more!
Would recommend this floor preperation to feeders!
I doubt that I'll be putting 2 tonnes on the floor (even with a quartz kitchen worktop). So I'm now going for...
- Beam and Block
- Ardex DPM 1 c (2 coats of sbr 1st coat 1/3 2nd coat at 90 degrees to first coat 1/1)
- Ardex P4 primer
- 40mm Wedi Board
- Ditra
- Porcelain tiles
- DPM plastic sheet on the walls
Does anyone disagree with this?
And can anymore recommended the flexi adhesive to stick the wedi down (should I keep with Ardex)?
the reason for using 2 x20 mm boards is this from my experience of kitchens the chances are you will have a load of pipe work running over the floor between the insulstion. the first layer you would run up to the pipe work and between it . the second layer at 90 degrees to the 1st bridges these gaps it also allows you to level the floor if the sub floor is uneven by using wedi there is no need for ditra as it effectively decouples and waterproofs so no need also for dpm plastic up the walls as the tanking takes care of that. I have done a couple of floors were ive used this method and done them both in a day.
another way would be to rip up floor cover with a dpm then screed out with 40mm semi dry screed and bed the tiles in using cement sbr slurry that's the way I would of done it 20 yrs ago and again all done in a day🙂
I have 4 pipes: 1x water, 2x waste and 1x capped gas. The two board solution is interesting. Ideally I want to lay the least amount of board possible (i.e. once at 40mm). But this will difficulties around the pipes.
DPM on the walls too instead of a plastic sheet then.
Removing the need for Ditra would save several hundred pounds. I guessing the foam acts as the decoupling between the two backer boards.
Given the price of Wedi, would going back to (cheaper) Marmox board do the same job? The specification seem very similar (if anything the Marmox seems stronger).
ive never used marmx so cant comment but if there like wedi ie water proof then yes
jmm,
bcd-87,
jmm,
bcd-87,
