Discuss Replacing Rubi TX900N with Sigma in the Australia Tiling Forum area at TilersForums.com.
Q
Qwerty
I've always been Rubi, but have been thinking of switching!
I am happy with my TX900N but I am totally bamboozled with which Sigma model would be the best replacement.
I'm not sure if I could get my head around the "pull" type but need a similar size cutter.
A bit miffed that only the mid range Sigmas have cases available for them or am I missing something?
Help & suggestions appreciated!
Sigma UK
Hello Geoff, The original handle "Standard" is pull towards you but you can change them to what you want. MAX is push and so is the Klick klock. None of the cutters come with a case but you can get a standard case that will fit any cutter up to 75cm with a bit of room to spare.
Stef
As above no need for a box,
These are 2 of my Sigmas in the van,
I would go for the 3DM, it's a push cut as I can't get on with a pull cut Sigma.
On one
They don't need a handbag with them like Rubis. They are robust enough to chuck in the van without much care - although I'm sure we all look after our tools eh?!
All mine are max handles from 40cm to 123cm and all work brilliantly.
Fearing the worst being without a case, I kept the corrugated cardboard box that my 3DM came in and beefed up the corners with gaffer tape. Works for me!
Reply to Replacing Rubi TX900N with Sigma in the Australia Tiling Forum area at TilersForums.com
I need a tile cutter gor 600x600 Italian porcelain and am close to pulling the trigger on the...
Hello, I have a Sigma 66cms 2B3 tile cutter (I normally do small jobs, standard size tiles) but...
5K
L
Hello! I am new here but I have been reading a lot about manual tile cutters on the forum. I am...
29K
L
I'm looking at a nice manual cutter from rubi. I'm set on a rubi as their parts are easy to get...
5K
Hi all I've noticed that when cutting large format porcelain on my Rubi TS70 plus that I...
5K
Dumbo
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
