Guest viewing is limited
Retro fit ufh & Hydrogen gas causes floor failure.
Do you seriously think we'd point the finger without first checking every avenue?
Tom you disappoint!
Tom you disappoint!
Not really, I am only asking questions.
As I have said, I have never laid on the foil faced boards but I do know what clients and manufacturers/builders/shops are like for pushing the job on or materials to be used etc without doing their own due diligence on the subject.
I, for one, am glad you have brought this to the attention of the tilers.
Maybe if you had explained your thinking in the first place I wouldn't have been so incensed at your question Tom.
Fair enough.
Believe me, we have researched this to death, left no stone unturned.
We have spoken with every tech department concerned, there is only one conclusion, it's an install error unfortunately.
So now that the foil has had a coating of adhesive and the chemical reaction has occurred is it that, for want of a better term, it's all burnt out and it has nothing left to react?
To quote Nick Knowles "Tiling is easy, any old fool can do it"
How many tiles you replacing ?
If it all going to fail are you not just put a sticky plaster over it....🙂
Bout 10 Andy, yes quite possibly.
All the indications are that it will ultimately fail, but you know how it goes
"I've been using hardboard on my floors for 20 years, never had a problem!"
Sometimes that's true, sometimes it's not.
It's not been down very long Paul and aluminium is still visible in places, and everything we've read would suggest that it will continue to react until either the aluminium or cement has been removed.
This reaction is actually used in a controlled way in certain circumstances.
Heavy machinery supports for example, when the support legs are concreted in they use a grout made up of cement and aluminium powder.
When the elements react and the expansion takes place, it fills any voids remaining in the concrete.
Old Mod,
Simons70,
Old Mod,
Simons70,
