Retro fit ufh & Hydrogen gas causes floor failure.
How many problems do you have ..
Do, as I did,
place, a concrete panel 6mm. (Without adhesive).
Tape on junctions.
And use epoxy adhesive.
that's no good?
It will still react with dry concrete, only a little slower.
The procedure was dictated by the heating plant company.
(German).
A 6 mm panel was used.
For thickness problems, I think it's ok even 10mm.
Epoxy adhesive, being only 6 square meters,
Kerakoll said that h40 no limits was ok,
But, to exaggerate, he said to use h40 extreme (epoxy adhesive)
the only one I've done I stuck down ditra with mapei two part then tiled.
why would people us this system when there is so many others out there which should be less problematic to tile onto.
Old Mod,
Simons70,
Old Mod,
Simons70,
