JordanLincs
I bought the TX-900-N and it's faulty I think 🙁 When sliding the cutter arm on the rails, near the top end its very stiff. Re-oiled and made no difference.
You don't oil, clean the rails and try dry lubeI bought the TX-900-N and it's faulty I think 🙁 When sliding the cutter arm on the rails, near the top end its very stiff. Re-oiled and made no difference.
I spoke to Rubi Rep who advised WD40 the rails, clean off WD40, then use 3in1 oil to lubricateYou don't oil, clean the rails and try dry lube
Which rep?I spoke to Rubi Rep who advised WD40 the rails, clean off WD40, then use 3in1 oil to lubricate
I changed cutters and this one works perfectly 😀
Not sure I should mention his name.Which rep?
