As it Is likely to be dirty particularly with dust a light sanding to loosen any racked in dust followed by a good vacuum clean is appropriate. Do not wet clean it.
Then prime it using a standard acrylic primer. Bond it will undoubtedly have one available.
As you are using granite which is a natural stone it is also appropriate to use an uncoupling membrane such as Ditra or Durabase. This is a recommendation of the stone federation.
Your screed dimension is just about at the point where it should have a movement joint it based on the depth and overall size you will probably get away without one but to remove any long term risk of movement cracking uncoupling becomes more important. Looking at the size this should not add a significant cost to the job but will save you the grief of cracked tiles later on.
