Discuss Self Leveling Tips? in the Australia Tiling Forum area at TilersForums.com.
Stef
As stated above, always prime the floor as it helps in letting the leveller flow.
Never ever try & guess the amount of water to use, I use a measuring jug to get the water ratio bang on.
Use the big BAL buckets & mix a whole bag at a time with a paddle mixer.
I never ever use a trowel, I pour as I walk & depending on the area size I will pour a half dozen buckets out & then use the spike roller to let each pour flow into one another.
If your going over a wood floor then mark out the room 1st with a spirit level & insert screws round the room set at the level with spirit level & that will then give you a depth to pour the leveller to, not an exact science but your not far away with this.
When looking at slc try & get the highest ratio water to powder you can get as this flows a lot better.
TileMaster rapid level 30, I use 5lts to a 20kg bag.
Mapei Ultraplan Eco for concrete floors I use almost 6lts to a 23kg bag.
Stef
Nice tip stef about the screws!
Do you use the spiked roller over Ufh? I don't do a lot of levelling but if it makes a big difference I might invest in a roller
Yeah, every time I use slc i use the spike roller.
This is TileMaster rapid level 30 over the top of an Ezewarm heat mat.
Reply to Self Leveling Tips? in the Australia Tiling Forum area at TilersForums.com
Just wondering everyone's thoughts on leveling schluter curbs. I'm installing a shower kit on...
Hi all. I don’t really post, I get all my info usually from just searching. I have just...
Our ground floor construction is a mesh reinforced structural concrete floor that was poured...
Self Leveling Tips?
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
