Discuss setting out a floor in diamond pattern 45 dgs in the UK Tiling Forum area at TilersForums.com.
Ken Bruty
1,023
Bedford
Dean, you're a star. Many, many thanks for this. Any good tips for how to ping a chalk line if you're on your own? Fix one end under a box of tiles?
Has your chalk line got a ring at one end? If so get some concrete nails, then take one and tap it into the subfloor a few mm far enough so that it will hold the tension of the line when you pull it tight then walk to the other room pull it tight and ping it to your marks, then just remove your nail. Job done! :thumbsup::thumbsup:
White Room
Just check theres no pipes to close to the surface
Diamond Pool Finishers
or get the BOSH GTL 3 lazer :smilewinkgrin::smilewinkgrin::smilewinkgrin: and set in place!!!:thumbsup:
Reply to setting out a floor in diamond pattern 45 dgs in the UK Tiling Forum area at TilersForums.com
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
Hello! I'm buying natural stone for floor in my house. Wife would like to do a French pattern...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
