Discuss setting out a floor in diamond pattern 45 dgs in the UK Tiling Forum area at TilersForums.com.
i have some more but they are form tasks that were don when i had the center. some of them may not be relevant. but i will post them if people are interested.
Dean, you're a star. Many, many thanks for this. Any good tips for how to ping a chalk line if you're on your own? Fix one end under a box of tiles?
that would be my fear. think i'm going to avoid hammering anything into the floor. pipes should be a good 3cm below the surface, but sod's law says that the pipes weren't clipped properly & have floated towards the surface.Just check theres no pipes to close to the surface
Has your chalk line got a ring at one end? If so get some concrete nails, then take one and tap it into the subfloor a few mm far enough so that it will hold the tension of the line when you pull it tight then walk to the other room pull it tight and ping it to your marks, then just remove your nail. Job done!
Reply to setting out a floor in diamond pattern 45 dgs in the UK Tiling Forum area at TilersForums.com
