View the thread, titled "setting out question .........." which is posted in British & UK Tiling Forum on Tilers Forums.
Hi
Is it possable that you could pack the cill out with plasterboard to make it higher , giving you a larger cut for your next tile
does anyone else get the 5mm syndrome, at least once a month for me lol, say you measure with your rule for instance 158mm and you mark and cut 153mm!!!! or is it just me😳
i have a brilliant solution, just set the new worktops that little bit higher to make up the difference(if possible):thumbsup:
potentially that is not as crazy as it sounds , and indeed i do have the option to do it if i need to , it might only be a few mm but it could save the day , deffo worth bareing in mind :thumbsup:
Reply to the thread, titled "setting out question .........." which is posted in British & UK Tiling Forum on Tilers Forums.
