jason67
Hi All
I’ve just had a loft conversion with one of the rooms being a bathroom. The floor is P5 grade (the green tinted moisture resistant stuff) 22mm chipboard and has been layed absolutely flat. The walls are skimmed plasterboard.
I would like both floor and walls tiled but it's the floor I'm concerned about. I’m using Wickes ceramic Tiles 33x33cm (8mm thick) for the floor.
I’ve bought Hardibacker boards to lay on the floor, but havn’t fitted them yet as I was hoping my tiler would quote for this job along with the tiling. Would it be reasonable to assume that laying Hardibacker boards is a job that a tiler would undertake?
I had an experienced tiler come to give me a quote yesterday but was surprised to hear him say that I don’t need Hardibacker boards. He said that he uses a special rubber based adhesive to fix the tiles directly to the P5 chipboard flooring. I’m a little concerned that this is not the correct fixing method and that Hardibacker boards should be used.
Could anyone give me a little advice on this?
