DSCN2112.jpgPINK ENTRY MURAL FOR SLIDE.jpgwhole view.jpgclose up of edge.jpgDSCN5117.jpgDSCN5113.jpgDSCN5119.jpg
these are a few of my latest jobs. The last is obviously unfinished in those pics. It's an outside shower- curbless. I ran the stone floor up the wall to make the space look bigger- It worked. Was a pain to set the floor tho because the drain was just 3/4" lower than the wood deck that the stone butted up against where you step in. 001.jpg here's the mural finished
i like the entry mural.. very extraordinary in design and i never see things like this handcarved without a waterjet .
thanks for these links.
i will get in touch to see if ship to uk.
i need something strong , but simple and not too big for stone work in bathrooms and this first link could be answer .
i have other bigger cutters up to 1200mm ali manta italian , which are nice and light but the the legs have had it after only two years.
this meistergold fahrbahr looks good for transportation. do you have any problems with head moving and cutting offline as it is only sitting on a single rail.
Fantastic work Makena, what sort of tools do you use cut out for the leaves from the face tile..
I use a Gemini Ring Saw.
However- I also do overlay murals- thin cut glued with epoxy to face of stone
sep 9 195.jpgDSCN3199.jpgpaper thin yet 3D carved. Once the edge is grouted- your unable to tell that it's not cut in. The back of this turtle is from an 18"x18" piece of slate. Smaller turtles are made with a single piece of tile.
well-I use a ring saw to cut the shapes out- and a Grinder to carve shape into it. On floors- has to be mostly flat- but on walls I like to do this22 119.jpgfloor mural 039.jpgthe design is one I invented- the idea is there is no right side up- going in or out- it still looks like its facing the right way. It's my best invention! Works with bamboo as well.
Entry_Tile_Mural_Tropical_Floor_Inlay.jpg this is the first multi-directional entry mural I made. All different shades of Travertine with slate flowers.
ENTRY_MURAL_PINK_MARBLE_LEA.jpg top view of the pink one. Its 8 ft wide!
adelaideplot1 049.jpgadelaideplot1 003.jpgadelaideplot1 059.jpgadelaideplot1 017.jpgadelaideplot1 008.jpgadelaideplot1 035.jpgadelaideplot1 037.jpgadelaideplot1 042.jpgadelaideplot1 022.jpgadelaideplot1 032.jpgadelaideplot1 030.jpgadelaideplot1 047.jpgadelaideplot1 048.jpgheres is the a project that has just been finished.
new build using mixture or porcelain and mother of pearl mosaic.
impey deck tray and tanking.
Featured Threads
