the corners of pool had an inverted quarter circle which also presented a problem, only because the client wanted to see the same margin of water line around perimeter of pool on semi submerged pool coping.
taking in to consideration that we had to have fall back in to pool anyway the only way was to fix this sections high and then we ground the corner areas down afterwards to get an even line to pool water line .
you cannot see very well the genuine antique jerusalem random reclaimed stone on pool shower walls and feature walls .
we also used antique grey barr for radiused steps to dining area and jacuzzi. to get a good finish we used a needle gun.
area at bottom of waterfall end was random mixture of stones boned to darin without mitres.
all corner pad stones were ground down after fixing as i had an obsession at the time about mitres on corner of copings that i though unsightly.
i now takea slighgtly diffrent view at times as it is so hard to grind and hone stone on site to match finish from factory.
Bathroom I did last week. Suite out & same one back in. Wall tiling only.
ceiling was the first of this type i had seen. it was a stretched rubber of sorts. we arrived one day just after it was fitted and there had been a huge leak . it was sagging in middle and touching the pool . they simply sucked the water out and heated it up and stretched back tight. Amazing.
all the bullnosing and quarter rounds and special degree bit made for waterfall end was done with a simple de walt router adapted for water.think it only cost £ 500.00 . what a great tool.
pool corners and roman end werent perfect but made a swinging arm as near to a true radius as poss and then reduced the angled cuts to copings and grilles to get as near as 30mm overhang as poossible to mosaics underneath,
Didn't know I could put up any work.
Heres fitted wardrobes I finished today
Done the new ceiling, lighting & decorating about 2 months ago. Got me back to do the fitted wardrobes
Tiling Work Showcase Forum
Dave,
Old Mod,
Dave,
Old Mod,
