Shower room floor prep
Currently removed the wall and floor tiles and shower tray from the shower room im renovating.
The floor boards look okay but have quite a few holes...
Plus one more out of view.
Someone on another thread mentioned overboarding with a tile backer but im wondering if I should replace the lot.
If so what's the best practice and thicknesses to use?
Ply, prime then tile straight on top
Or ply followed by backer board then tile?
I would say it depends on the floor, if its very sturdy, no deflection then I would be tempted to patch the holes and overboard with hardiebacker .. If there is movement, squeaks etc then take it up.
18mm ply min - SBR on all surfaces, even the edges
Glued (Polyurethane glue) and screwed down
Overboarded with hardie then tiled.
Upvote 0
Thanks for the info.
when it comes to over boarding with hardiebacker, is it just screwed down to the sub floor? whats the best thickness to use and do i need to do anything at the joints?
Thanks again
Upvote 0
Sorry for the delayed reply. Set the hardie in a bed of adhesive, I use a 6mm trowel, then screw it into the ply only not the joists. I generally use 20mm screws. dont forget to tape the joins up
Upvote 0
Best Bathroom Tiles
Unsolved
serval,
serval,
serval,
serval,
