Shower tray installation
Jrterror
Hello.
We are currently in the process of renewing our ensuite.
I have been trying to get to grips with the different types of shower trays and their methods of installation.
The shower tray that was removed; I believe was an acrylic tray. It was very light and was raised off the floor through the use of 3"x 2" timbers, with a plywood base sandwiched between the underside of the tray and the top of the 3x2s.
Is this type of installation typical for an acrylic tray? I was surprised not to find the tray raised on legs instead.
Anyway, that tray is going in the bin and we intend to buy new. So which type of tray would be best for sitting on top of and existing wooden floor. It will need raising, because of drainage pipework. But I can't decide upon which type of tray. Another acrylic, because it's lightweight or stone resin or stone cast. Can all stone resin trays be raised up on legs or timberwork? Are they self supporting? What I mean is, I read one manufacturers installation instructions and it stated it must be set on 5mm minimum concrete or on legs. I couldn't work out why it can be mounted on legs yet if installed without legs it must be bed on a concrete base.
So I suppose I'm asking which is the best installation method for each type of tray? Acrylic, resin, stone.
I thought it best to ask fitters rather than manufacturers because you fit them and have to deal with them day in day out.
Also, because the ensuite is in the first floor above the kitchen are there any other considerations. Maximum weights, or tanking or shower sealing tapes.
The have so many questions. Haha
Your help would be greatly appreciated
Ta
We fit a few stone resin trays and can't get our head around there requirements but when bedding them we use flexible cement based tile adhesive as sand and cement at about 5mm thickness is pretty weak
If you're unsure then just choose the type of tray and then follow the manufacturers recommended fitting instructions.
If waste pipe or joist position is an issue then my choice would be pretty much the configuration you have now - build a timber frame, lay 18mm ply on top and sit a low profile stone resin tray on that, using either a flexible tile adhesive or flexible grab adhesive.
Thanks for the replies
Plan Tec. I was just wondering which is the best type of tray for our setting. Also, II don want to purchase a tray online, only to discover that it is not suitable for raising. Unless Al shower trays can be raised. The difficulty is finding installation instructions prior to purchase, to check the method of install.
Regarding your comment, is a timber support superior to legs? And why adhesive, instead of just sitting it on the ply?
Ta
With timber supports it spreads the load better rather than having 4 legs supporting the tray,
The reason you need an adhesive is to stop any movement in the tray which in turn will lead to leaks.
We use Mira Flight Low trays quite a lot, they have an optional riser kit (legs & plinth) so easy to achieve the height you would require I'm sure!
I have fitted 3 mira flight trays and love the ones with 4 upstands Mira Flight - Square - 800 x 800 - 4 Upstands by Mira Showers - https://www.mirashowers.co.uk/shower-trays/mira-flight-square-800-x-800-4-upstands/.
The tray is chopped into the plaster so that the thin upstand/flange fits flush with the plaster then you tile down the plaster and down onto the tray - leaving 5 mm Silicon gap. The shower cubical fits inside the upstands meaning it is impossible for the cubical to leak at the bottom.
I dont trust the strength and stability of the leg kits - they are like kitchen cupboard legs and so prefer to use lengths of 3x2 ontop of the floorboards and 90degree to the joists. ontop of that I add 18 or 22mm ply and sit the tray on a bed of no nails type adhesive but really most of it squishes out and the tray sits on its slightly raised bottom form sections with the adhesive around those. I make sure that the ply is smaller than the tray to allow whatever cover panel I am using to sit nicely under the tray. One more thing is that the rubber seals that come with waste never seem to be watertight no matter how fancy they look so I use plumers gold Silicon in between every rubber seal on the waste
These type of waste I think are the best that have a hand tight base that you can remove to clean out. BUT make sure that your tray is high enough to allow for it to drop down once unscrewed or cut out a section in the floorboards to allow it. And make sure that you plan the wast position so that the waste is at one of the two sides just behind your covering panels
here is mine after it is removed and cleaned. And I have just found the pictures of the base. I did not want to block any view of underneath once the side access panels were off so I did not use lengths of 2x3 but instead used blocks first set onto 18 ply mats. I screwed the blocks from under the square ply mats and then screwed down from the top through the ply mats and into the floor then set the full 22mm ply base onto that.The photo is before anything was screwed in place, as I did not want to block my access to the waste I used two kitchen legs in that area but the heavy and strong tray on 22mm ply would of happily sat floating there.
You will also see that the pipe joints are only at the front so I can inspect them the 2nd pipe is the bath waste. The only thing that perhaps I should of done is use solvent weld.
I also sealed the floor below so that in the event of a leak it should show itself under the cover panels and not drip for months down to the ceiling below, I also painted the floor white so that it is nice and bright when I shine a torch under there
We have always used the legs provided and have never had a call back!
What sort of enclosure are you intending on putting on top?
I'm not a massive fan of the upstands, if you do everything properly it shouldn't leak...
here is mine after it is removed and cleaned. And I have just found the pictures of the base. I did not want to block any view of underneath once the side access panels were off so I did not use lengths of 2x3 but instead used blocks first set onto 18 ply mats. I screwed the blocks from under the square ply mats and then screwed down from the top through the ply mats and into the floor then set the full 22mm ply base onto that.The photo is before anything was screwed in place, as I did not want to block my access to the waste I used two kitchen legs in that area but the heavy and stromg tray on 22mm ply would of happily sat floating there. I also sealed the floor below so that in the event of a leak it should show itself under the cover panels and not drip for months down to the ceiling below, I also painted the floor white so that it is nice and bright when I shine a torch under there
View attachment 97181 View attachment 97182
You could do with tanking that wall before tiling!
Tanking and Wetrooms
Jrterror,
martin1c,
Jrterror,
martin1c,
