nope, tiled after tray was siliconed to wall then tiled down to tray less 5mm it seems Silicon did not bond to grout, and water ran behind Silicon at the vertical joints may also have leaked at internal corner of shower cubicle which was siliconed over grout, i have not had this problem in the past, used mapei grout and unibond sanitary Silicon
Don't suppose you've still got the Silicon? Silicon does have a shelf life so check the use by date. It will be much dryer if past it and will not adhere as well
