whats the best Silicon sealant to use in bathrooms and shower rooms for sealing ???/
Hi Electric,
I'll throw in my pence worth. Since we embarked on the cornertape project we have come up with a few interesting bits of information and practices which maybe weren't apparent before. I'm sure at least, a couple of these could explain in some part the premature failure of some joints. I don't mean from mould but from the Silicon de-bonding and coming away from the surfaces.
Because of how the cornertape works it has highlighted a problem that we don't believe anyone gave a thought to in the slightest. This being 'the surfaces may be clean' but are they 'degreased', it is quite obvious that if you apply Silicon to a surface that has not been 'de-greased' correctly then the Silicon will not bond to it as effectively. There are many cleaning wipes out there that are great at removing wet Silicon from places that you didn't want to get it, but if used to wipe the surface down before the application of Silicon, all you'll be doing is ensuring that the surface is covered in a thin layer of solvent/oil and hence the reason that Silicon joints pull away from the surfaces like a long piece of string at some point.
Also it appears that some people also use oils and the like to remove grout haze from newly installed tiles, again this is also bad practice for obvious reasons.
CornerTape don't do Silicon and I can safely say that the finish you will get from using CT will be perfect regardless of the type of sealant used (cheap or expensive) at the time of application. However we do agree with other comments on here i.e you get what you pay for or at least your customer will in the future.
I have also seen quite a few bath installations where the Silicon was sat below the top surface of the bath, this is just asking for problems, like mould because water will just sit on top of the Silicon and never dry out. There are lots of posts on here about the correct way to seal a bath.
So to re-cap - DEGEASE the surfaces before doing any Silicon work with pure ethanol. -CornerTape System Cleaning Wipes
are perfect.
Buy a Silicon that clearly states that it is 100% Silicon with a mould inhibitor.
Best regards
Andy
P.S i'm sure someone will have their own views on my comments.
