Silicon
Cheers will give them a try. Always use washing up liquid and finger - wife not to keen on sticky fingers - at least not until after sex 🙂
Its the washing up liquid and the water that does the trick, best tool on the market is from screwfix (orange) or wicks (blue) , like a finger with a hard rubber profile on the end £2.75, gets behind the taps. The ones from trade tiler at about a tenner are the Karl Damm ones, Tried them, there at the bottom of the tool box somewhere
I got one of them ones from Wickes. Just the job 🙂
Finish it off with the lightest touch with your soapy finger just to get rid of any little strayed bits on the wall
This works a treat Darren!!! No more dirty jumpers for me..... just finished your course (April 13) and i have to say its the best thing i've ever done. Can't thank you enough for everything i've learned! Will be back for the natural stone course soon as as i have the money together!
I've got a couple of those "rubber things" and the best one gives a mitre finish which really finishes the job off nicely.
I can use the old little finger when it's Caulk but silicones require a professional finish In my opinion.
I find the spray bottle technique is very good, I also use the orange screwfix tool when I can as it keeps silicon off my fingers. Which side of the tool do you all find gives the best finish? I have used the sides on some occasions when the customer only wants a very small silicon joint as the tool is sometimes too wide. What size silicon bead would you say it works best for?
Screwfix only appear to do this one now and a fugenboy set for £10
[DLMURL="http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A236074&ts=49214&id=10994"]Sealant Tool - Screwfix Direct, Everything for the Trade, Next Day![/DLMURL]
The one I have is finger shaped, is this the only you refer to darren?
screwfix sell the finger one also i got mine from there its orange with blue end only £2.49
The orange with blue end was screwfix code 10994 in the older catalogues. Code 10994 now shows the new silcon tool as per the previous post.
Silicon
h0ndatyp3r,
Traxman,
h0ndatyp3r,
Traxman,
