Discuss Simple way to mitre a tile..................Mitre Wiz in the UK Tiling Forum area at TilersForums.com.
Mitre Wiz
Hi Guys,
Thanks for all of your previous feedback it has really helped since i was last on here. Mitre Wiz is an attchment that will go on any grinder that makes the skill of mitring a tile very simple. Since i was on here last we have been working hard on making the tool safer, faster and simpler. Many thanks to those replies last time your feedback was very valuable and improvements were made from your constructive criticism. We have recently done a couple of new videos and have upgraded the tool itself. Would be great if you guys could again have a look and tell me what you all think. Not far off release and will arrange some samples through this forum.
Perfect Mitre Edges in Seconds with The Mitre Wiz - YouTube
The Mitre Wiz is making cutting simple! - YouTube
Once again thanks for your time and feedback
Mitre Wiz
Hi there,
Thanks for your reply. You will be so impressed how easy it is too use certainly does work as well as the video suggests. It def helps to have quality continuous diamond blade but it is so simple. . Do you do a lot of mitring or do you tend too use trim. Check this video out and it gives you a better idea of how quick and easy it is......
The Mitre Wiz in action. - YouTube
Thanks again
cheers
Time's Ran Out
I don't think that the price should be a deciding factor on it's benefits. In my opinion the sooner plastic trim is outlawed from the professional market the stronger the reputation a tiling contractor will gain.
There is no substitute for a perfect mitred edge and the additional time taken to provide a continuous surface of tile is to be admired.
Reply to Simple way to mitre a tile..................Mitre Wiz in the UK Tiling Forum area at TilersForums.com
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
uHeat and TilersForums.com go Way Back - And Continue to Partner-up to Bring You Savings on...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
