C
cornish_crofter
only reason I gave it another topping today Hugo was because it was a garage that had been converted into a fitness and utility area, I'd reformed the floor where the car pit was but hadn't successfully dammed it, so the slc was weeping into the pit causing depressions in the surroundng areas. I decided to leave it yesterday so that the surrounding slc would seal the gaps and it did, so I just went back today to top it all up.
I know it does eventually stop seeping out as it sets quite quickly.
I am just trying to understand whether you got it to behave a bit like a screed and get the 50mm all in one go. If I had my time again I would have set battens at 10mm high from the mid point but level and filled the bays. I've got some lengths of door stop that would have achieved this.
