Guest viewing limit reached
So where does the water go?
GRR you using an over bath screen? If so id lay my money on the water getting through there somewhere. Sometimes they can let water through the gap between the male and female channels and through the hinge mechanism at the bottom.
Iis quite common to get a damp patch by the edge of the bath at the base of the screen, just needs drying off and some additional Silicon at the base of the hinge.
sorry boys, it's a shower rail and curtain. when the curtain is in place, I make sure it's all the way round, fully in the bath etc. I'm convinced the failure is somewhere between the bottom row of tiles and half way up. i've checked the Silicon over so many times, taken it out twice and re-done just to be sure. there has to be a pin hole somewhere in the grout that I haven't found yet.
but thankfully, at least I can see that there is a failure somewhere and that the water is finding it's natural path out. otherwise if it was sitting behind the tiles, I'd have bigger problems.
I can check it for you Liz, will call around next week. You will have to be using the shower in order for me to........................
errrrrrr.............I'll stop now
:shocked3:
:shocked3:
thanks for the lovely offer Dom but I think not :ban:
G R R do you have tap fittings in shower area they should be sealed around to from tile to tap mechanism ( not to tap cover or flange) this is one of the main areas water will get in
nope Jay, no taps in the walls either. shower riser rail is at the top half of the wall and I cannot see how water will get up that high even when I splash around. I'm thinking the grout may be too thin in some areas, so once I've finished my uni assignment this weekend, I might actually get my act together and start a re-grout :lol: It needs doing. I'll be waiting till next Christmas if I asked Mr GRR to do it :lol:
taps outside shower
nope it's a bath/shower mixer tap, so the tap is attached to the plastic bath. i've checked the fit of the tap too and there's def no water leaking through it. i'll find a way of repairing it :grin:
but at least I know where the water is going and that the tanking kit is doing its job :yesnod:
Couldn't it just be condensation running down and collecting, Liz, from the wall, taps or curtain?
doug boardley,
Dan,
doug boardley,
Dan,
