Sockets on split face tiles
As @Paul C. To get anywhere near decent partially cut in faceplate and also use a bucket of Silicon . But yes good luck keeping it clean
I have always recessed the tile so the socket sits flush with the thinnest part of the tile - thought that would be common practice?
Haven’t done it with porcelain only slate but the process would be the same.
Mark around your socket and remove as much material as you need so it sits nicely..
Yeah meant just for trimming down a little main cuts would be grinder but just to plunge cut the small recess.
Was just a thought.
yes, I usually do
first I try the flat tiles, then
if necessary use the grinder to grind
those that bother plaque.
Thanks how do you remove the material to get a nice right angle for the sockets? What tools used?
dg-1984,
dg-1984,
dg-1984,
dg-1984,
