I have been using a LAX 50 in a recent en suite job. It is very easy to use and quick to set up. It comes with spare batteries and an integrated stand/ case. I thought it was very good value for money and the ability to rotate it on the pole through 360 degrees so that levels around the room were equal was amazing.
Cuts down "measuring up" time down to less than half what it what normally take. I quickly established that the coving was out by a couple of cm's at each end of the room and this meant I adjusted my
tile setting out accorsingly so I had no tiny cuts.
The extendable pole has a rubber buffer at one end too so the newly plastered and painted ceiling in the room was left scratch free and unmarked.
Does anybody have one of these lasers...?
I am thinking of getting one for a big job i have coming up for ease of datums etc..
My question is... I notice there is no pendelum lock on it... so have you had any calibration issues etc..?
Dave, the ON/OFF switch is the pendulum lock. I check it every day before use with my STABILA spirit level, and have found no problems at all
