Discuss Sub-floor board in the Canada Tile Advice area at TilersForums.com.
I push to go with screed,not necessary with pump,we can mixed in place,cheap and good solution,easy to archive perfect level but seems to accept the quote with marmox.If your just a tiler. Your words is it not Wise to pass this part of the job on to someone else . I still think celotex and pump screed is best fix . Weight will not be an issue on solid floor .
Why would he be worried about weight. Is there something he knows .I push to go with screed,not necessary with pump,we can mixed in place,cheap and good solution,easy to archive perfect level but seems to accept the quote with marmox.
Is not new building,was changed in open spaces offices and the architect is worried about weight.
Yes,I think!Why would he be worried about weight. Is there something he knows .
Fair enough . But make sure your happy with what you are doing because if it goes wrong it's you he will be looking to .Yes,I think!
Anyway is not too much difference between screed and marmox+Knauf+adhesive,screws etc,but is not my call...
With marmox cost 3 times more then screed,delivery in 2 weeks time.Fair enough . But make sure your happy with what you are doing because if it goes wrong it's you he will be looking to .
Thanks for that local. Seems I've been doing it right all these yearsThe only time you do not need to mechanically fix a marmox type board is when you are sticking it to a solid floor. I,e not wood
Reply to Sub-floor board in the Canada Tile Advice area at TilersForums.com
