You’ll want a modified thinset if your tiles are porcelain.
I can’t imagine them to be ceramic
if they’re 36” x 6” and a specified floor file.
(I could be wrong of course)
Ultimately it’s going to rely on the amount of
deflection in your floor.
Here, we would not choose to tile on to OSB, exterior grade or not, we would want it replaced with a more suitable material or it would be overboarded with an inert flooring board,
(glued and screwed) Hardiebacker or cement board equivalent, or XPS type board like wedi.
Timber, no matter what type, is a poor choice of substrate on which to tile.
It’s subject to far too many variables as to whether or not your install will have any kind of longevity. (Expansion, contraction and moisture)
Timber is not a stable material.
A matting like Ditra 25 or your laticrete mat will only assist with lateral movement of your substrate, not deflection. (Side to side, not up and down)
Hence our course of action would be to exchange the OSB for something more suitable like 55/64” hardifloor not herdiebacker.
Failing that, the overboard route would be taken.
A quick deflection test would by to place a brim full glass of water in the middle of your floor and see if you can make the water spill by stamping on your floor in close proximity to the glass.
Better still a horizontal lined laser, and watch for the line to vibrate when the floor is stamped on.
If it vibrates, then there is too much deflection present.
The only other way to make your floor more stable without the extra height, is to add more cross braces between your joist, this should help reduce the deflection.
Ultimately, the choice is yours, especially as you’re installing your own tile, a professional should refuse in its current condition.
If you can remove all deflection and mat over the OSB with Ditra or similar using something like Ardex AF200 adhesive, then you may have a floor that will work.
But with a 6” x 36” tile, there is a high possibility it will have problems if your substrate is not the best it can be.
Now the choice, really is yours.
Good luck.
Yeah I originally had no intention of putting tile on this floor because I didn’t trust it, then my wife found a tile she really liked and I couldn’t find a wood floor I liked.
I toyed with the idea of ripping out the osb and replacing it with something else if I had to. We have panels here called advantech at our local store (we do have a Home Depot, but sadly still no fairy dust there). Its still osb but supposedly much better. Your Hardifloor sounds like good stuff, I haven’t seen it though. I was surprised that the Ditra website says that a single layer of osb over 16” joists is suitable, but I know little about Ditra. I do have new construction so that may help I guess.
I have read that cement board offers no structural support but I do find that hard to believe, no doubt there is some. I am sure it’s more than Ditra though.
The tiles I’m looking at are indeed ceramic. I’m guessing long ceramic tiles are not in my favor to avoid cracking. I haven’t had a chance to actually see them and I’m not sure on the quality so I’m a bit worried they have a lot of bowing and warping but that’s another issue I guess.
I’ll see if I can get my hands on a laser, or at least a glass of water. That sounds like some good advice to me. You’re right, it is my floor and it’s not the end of the world of it fails. I’ll just rip it up and do over but it would be real nice to avoid that. Sure if it’s somebody else’s than you want it 100%. I don’t believe we have Ardex, I’ll have to look into that.
Thanks for the advice, definitely something to think about.
