Discuss Suzannah in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
I agree with MG that it is probably acid burn. The HG stuff is made with Phosphoric acid which is pretty strong. It looks to me like you have either taken off a "film" of something that was on the tiles or you have taken off the original dressed finish as the areas that are grey look like natural blue slate colour (which is a light grey).
Whilst I sort of agree with the salt theory I think a simple strearate based cleaner and a good old fashioned scrubbing brush might also do the tirck (i.e. soap and hot water).
Have you cleansed the whole slate or just the edges? Did you dilute the cleaner.
I did this with an old quarry tiled floor may years ago and a similar thing happened i.e.the edges stayed white and discoloured. I used to work in the food industry where the cleaning guys used mechanical scrubbers (like the old fashioned school caretaker) which I ended up using and after a couple of passes and lots of rinsing it came up a treat.
Remember it's an old floor so it is worth working on.
Reply to Suzannah in the UK Tiling Forum area at TilersForums.com
Hi all. After living in my property for over 7 years I've recently discovered the type of tile...
Hi ppl Need advice regarding sealing kitchen tiles. I believe I have lappato tile laid on my...
Suzannah
Tags
usa
