Switch won't physically operate Discussion ThreadSwitch won't physically operate Electrical Advice
I have this gewiss switch that is being used as a switch for a hot tub.
www.gewiss.com
It was tuned off to do maintenance on the hot tub but now won't turn back on the switch is now physically stiff. Do I need to replace or is there a chance that there is an easy fix if I open it up? I do have some basic electrical engineering knowledge and would be able to replace this switch myself just wondering if there was a simple fix
Switch won't physically operate for the original thread on Electricians Forums
VERTICAL FIXED INTERLOCKED SOCKET OUTLET - WITH BOTTOM - WITHOUT FUSE-HOLDER BASE - FOR HEAVY-DUTY USE - 2P+E 63A 200 - 250V - 50/60HZ 6H - IP66 | Gewiss
